Here is how to change out the fuel injector. Check out the images (below). Please let us know what happens.
Mar 7, 2025 at 11:12 AM
LESANDJANICE BUCKLEY
MEMBER
Have had a compression test, 10 PSI less than others. Fault applies whether on LPG or petrol so injector not an issue. Cylinder 4 coil swapped with cylinder 3, plug 4 swapped with cylinder 1, to no effect. Will intermittent faulty cam or crank sensor cause this fault?
Mar 8, 2025 at 11:44 AM
(Merged)
CERTIFIED EXPERT
I would remove the spark plug so make sure it is not cracked. I also have seen defective spark plugs as well, they look new but don't work.
Mar 8, 2025 at 11:47 AM
MEMBER
Plug okay, please answer re sensors.
Mar 8, 2025 at 2:50 PM
CERTIFIED EXPERT
If the fuel injector and compression is okay the crankshaft sensor may cause this issue. They don't tell us where they are on this vehicle sorry, but I did find information on what to look for. Check out the images (below).
