When pressing gas pedal engine backfires. did find filter from fuel pump strainer floating in gas tank. Did replace with new fuel pump and fuel filter. Did also replace spark plug wires and distributor cap. The spark plugs are less then two years old and looked good. Did clean the ignition rotor because it was black. i also cleaned the EGR valve and air flow mass sensor and throttle body. What do you think the problem could be? Thanks.
Jun 7, 2020 at 7:47 AM
