Intermittent fuel issues
1989 BMW 323
10 MILES • 2.0L • 4 CYL • RWD • MANUAL
W0Z
My car has an SR20 engine in it. Its a drift car. I am having a problem with startup. when i activate the fuel pump before cranking it works and i get pressure, but as i turn the key i lose most of the pressure and it the pump works under powered almost. Car just swings and swings until it kills the battery.
When the car does eventually start after lots of patience it runs perfectly fine with no power loss. This problem is only on startup and done with fully charged batteries.
Please help. Lol
Jul 7, 2016 at 4:36 AM
Hi when it is not starting you need to run some tests , it sounds like the crankshaft angle sensor.
this should get you started
Please let me know what you find
Best, Ken
Jul 12, 2016 at 8:34 PM
