Compressor replacement?
2010 TOYOTA COROLLA
69,000 MILES • 4 CYL • 2WD • AUTOMATIC
PETE SWIDERSKI
Thanks in advance for your help! Here is the situation with my A/C. I have had some issues, and finally took it to Big O tires. They evacuated and refilled to specs. No leaks all working fine. Now I have this issue and would like to know what is happening: On hot afternoons:
During a drive, works fine.
Return home and idle in driveway, works fine. (Tested for three minutes)
Turn off A/C, wait ten seconds and turn back on.
Here one sound (compressor), then fan on back of radiator engages.
Fan only stays on two seconds then turns off.
A few seconds later, compressor engages, fan engages, both shutoff after a few seconds.
This continues.
Take the car for a drive and it starts to work. Compressor and fan engage and stay on.
After five minutes come back to idle and it works okay again in idle until you turn A/C off and then back on. This throws it back into the cycle of compressor and fan not staying engaged.
Jul 8, 2017 at 3:08 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial showing how to replace an air conditioning compressor:
https://www.2carpros.com/articles/replace-air-conditioner-compressor
I've attached picture steps below on how to replace the air conditioning compressor on your car. Hope this helps and thanks for using 2CarPros.
Dec 29, 2020 at 12:09 AM
