I have a clunking noise when I start the engine sometime, I thought it might be the cooling fan or water pump, I have replaced cooling fan, water pump, serpentine belt and the thermostat. I the clunking noise stops once the engine is running, however, I have a clicking noise when car is in drive gear, sometime loud, sometime low, but much louder when I am in reverse gear. I checked the fluid level in the differential, its old but at a proper level. My next step would be to place the car on jack stands and check the universals and drive shaft while in gear. (Do you have any suggestions)
Aug 22, 2015 at 2:51 PM
