This issue started out as rarely happening and progressed to regularly happening. I press the brake and hit the start button (2015 Lariat with factory keyless start) and it started hesitating to crank and fire. There was no slow crank or dimming headlights. All lights came on the dash as expected but that was it. I tried to see if it would remote start and it wouldn't. I switched it to neutral and still no start. I replaced the battery with a new, 750 amp battery. This didn't help. The no start got more frequent with it taking several minutes of pressing the brake and the start button to get it going. I change the batteries in both remotes with no affect. I replaced the start button with Ford's OEM and no affect. I then replaced the brake switch with Ford's OEM and no improvement. I took it to a little country mechanic who basically stomped the brake pedal hard once and it started every time for him so I brought it back home. it started fine from a couple of days and then this morning, it took 3 tries to get it do anything. Any ideas!
May 21, 2021 at 6:28 AM
