It started with a dead battery, replaced 84 mo. batty after ten years of service. it was not battery. checked alternator, is not the alternator.
checked wireing, it's all good. checked connections they are all good. no frayed wires, no blown fuses, still only clicked when I tried to start it. pulled the fuses one by one with light between batty cable and batty. light went dim when ecm-b fuse was pulled starter began to work. reinserted ecm-b fuse it starts and runs and battery is charging. I can still hear what sounds like a fan runing. it seems to come from the TBI area. on closer inspection it sonnds like it's the throtle body injectors. isn't this the strangest problem? what can it be the GM mechanics ( 12 ) of them can't figgure it out.
Jun 15, 2013 at 4:11 PM
