Before this issue, turning the headlight switch knob to the right, after the click, would keep the interior lights off, even when I opened the doors. Turning the headlight switch all the way to the left after the click would keep the interior lights on continuously. That was perfect. Now, however, when I turn the headlight switch all the way to the right, the interior lights stay illuminated. In addition, I've noticed that when I have the doors open and I turn the headlight switch knob all the way to the left the intensity of the light increases just a tad. I must tell you this is after I installed a radio system. Also, when I pull the interior fuse from the panel under the glove box, the lights stay on. In fact, I can remove all of the fuses under the glove box and the lights will stay on. These are the interior lights I'm talking about not the headlights. The only way I can get them to go off and actually stay off is to remove the fuse under the hood inside that fuse panel box near the battery. It's a tiny little single like I don't know 15-amp fuse or something. You put the fuse in it's a mini fuse, and then you have to push down on this yellow cradle that it goes into, if that helps you at all. So, can you please tell me what I did to mess up and how I can fix it? Thank you in advance.
Jun 7, 2025 at 1:59 PM
