Interior lights not working properly
2018 CHRYSLER PACIFICA
45,000 MILES
CHARLES RANDLE
I created the following video related to an issue with my driver side rear courtesy lights.
https://www.youtube.com/watch?v=SiaXUa_iiDQ&feature=youtu.be
Oct 17, 2020 at 6:35 PM
Great video. That panel should just pop out and you can retrieve the light bulb. You may need to replace the actual piece as I am not sure that will pop back in as I have not seen one pushed in like that but once you get it out you will be able to determine that.
I attached the instructions from the manual for both the combination panel and the individual lamp. Your vehicle has the combination panel/bezel as it has the vent with it but others that view this with this issue may have just the lamp so that is for their benefit.
Let us know how you make out. Thanks
Oct 18, 2020 at 8:25 AM
CHARLES RANDLE
Thank you. I will let you know how it turns out.
Oct 19, 2020 at 12:19 AM
Sounds great. Thanks for the update. Let us know how it turns out. Thanks
Oct 19, 2020 at 6:21 PM
CHARLES RANDLE
It worked like a charm. Thank you so much.
Oct 20, 2020 at 8:53 PM
That is great info. So glad it worked out. Thanks for the update and the wonderful information. This post will surely help someone else in the future that is visiting the site. Come back again to 2CarPros.
Oct 21, 2020 at 6:50 PM
