If you look below, pic 1 identifies the box and fuse orientation and identification numbers. Pics 2 and 3 are the fuse number, rating, and circuits protected.
I'm not sure what you are dealing with, but if it is a fuse-related issue, first confirm the fuse is good, if it is, it's important to determine if the fuse has power both to and from it. If there is no power, it's likely a bad fuse in the under-hood box.
See pics below.
Oct 19, 2022 at 6:56 PM
