Interior fan not working all the time
2015 SUBARU CROSSTREK
79,000 MILES • 4 CYL • 4WD • MANUAL
ADAM NICHOLLS
So my interior fan is not working all the time, not sure if it's the fan, the bearing the fan spins on or the resistor switch. I have taken off the cover of fan and knocked with screwdriver and it started working. Any ideas a resistor is like $40.00. a new fan is like $350.00.
Jan 12, 2019 at 4:20 PM
If the resistor was bad, it would not work on and off. Usually, a bad resister will allow the fan to only work in high speed and no other. Now, is the fan making any noise which would lead you to believe there is a problem with bearing or the motor?
What I would suggest is this. It does sound like the fan is bad based on your description, but to be sure, when it fails to work, check to see if there is power to it and make sure it has a good ground.. If there is power to it and it has ground, but it still isn't running, the motor is bad,
Take a look through this link:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
I did find a technical service bulletin related to the blower motor. I had to add them as pictures. See pics 1-3
___________________________
Here are the directions for removal and replacement of the motor if that is what you need to do. The remaining pictures correlate with these directions.
REMOVAL
1. Disconnect the ground cable from battery. Ref. to NOTE > NOTE
NOTE:
For the 12 volt engine restart battery of HEV model, disconnect the ground terminal from 12V engine restart battery sensor.
2. Release the clips, and remove the under cover assembly - passenger.
See picture 4
3. Remove the blower - motor.
(1) Disconnect the connector.
(2) Remove the screws and detach the blower - motor.
See picture 5
________
Install is revers of removal
______________________________________
Here is a test to determine if the motor is bad. Picture 6 shows pin connectors to the motor and which one gets power and ground. You will need to provide battery power to perform this test.
1. Check the motor operation when battery voltage is applied between the terminals of motor.
Specification
Connection diagram see picture 6
Connect battery to the terminals
2. If it does not operate normally, replace the blower - motor.
Let me know if any of this helps or if you have other questions.
Jan 12, 2019 at 9:15 PM
