My interior dome lights in the back and front map lights up front work fine when you open or close the doors. But if you press the individual buttons to turn each one on both fronts and both rear nothing comes on. This is on a crew cab. It has the push button switches on both the front map lights that you can move around like a ball and the rear ones on each side of the regular center dome light. I've put in new bulbs both LED and regular and nothing happens when you push any of those individual buttons to turn them on. You have to roll the switch on the dash to turn on all the interior lights to get the fronts on but those back two don't do a thing even though i've verified all bulbs work fine. I don't know why the front two will work with the door but push those buttons and they go right out. Those back two on each side of the center one that does work do nothing with their switches. It's like those four buttons are bad but how could four buttons go back all at once together?
Jun 14, 2019 at 6:10 PM
