What are the size dimensions of the wheel-bearings?
2007 FORD FUSION
317,000 MILES • 2.3L • 4 CYL • AUTOMATIC
H4RL3Y_IAM31
My car is in serious need of front wheel bearings, and my problem is that I cannot afford them. So, I have a friend that's got totes full of different wheel bearings that he had when he ran his mechanic shop. So, he said if I could find out the size dimensions of bearing; the inside diameter and outer diameter and width of it. And/or a list of vehicles that the bearings are interchangeable with the car listed above SE. Please help!!
Thanks in advance,
Olivia
Jul 19, 2022 at 7:23 PM
Hi Olivia, if this is front-wheel drive and not all-wheel drive, the original equipment part number is, Ford 3M8Z-1215-A.
I looked up the info and found what is listed in the pic below. That provides every dimension relevant.
You can have him look up the part number above or National bearing part number 510010.
Let me know if this helps. Also, let me know if you plan to do this yourself. You will need a bearing splitter and a press.
See pic below.
Jul 20, 2022 at 10:37 PM
H4RL3Y_IAM31
Thank you so very much!! This is perfect and big help!
Jul 22, 2022 at 11:02 PM
You are very welcome. Please let me know if you have other questions or if you need help.
Take care and feel free to come back anytime in the future.
Jul 23, 2022 at 8:21 PM
