You can use most any vehicle that the transmission came in after 1995 when they made an upgrade to where the cooler lines connected to the case. If you look at the picture, the square was where the cooler lines attached from 90-94. Then in 95 they switched it to the rear location where the circle is. Plus there was a case different, it didn't have the top bolt hole for the LS engine in the bell housing. Lastly the linkage is shorter in the older units.
So you can use a transmission out of any vehicle that had the 4L80E after model year 1996. Just make sure it is the original transmission because many people didn't know the differences and made an older unit work in their newer vehicle.
The vehicles that used this were, Silverado, Sierra, Tahoe, Suburban, Yukon, and the Vans. There are more but these are the most common vehicles. Clearly if you can find one with the same model year in one of these vehicles then that will make it even easier.
Hope I answered your questions.
Mar 17, 2020 at 12:39 PM
