Here is what is said about the transmission swap:
It is not recommended to put a 2005 4x2 transmission directly into a 2007 Ford F-150 without further consideration. While the F-150 models from 2004 to 2008 shared many similarities, there can still be differences between model years that could affect compatibility.
To determine if the 2005 transmission is compatible with the 2007 F-150, it's crucial to compare the specifications and configurations of both transmissions. Here are a few factors to consider:
Transmission Type: Check if the 2005 and 2007 F-150s had the same type of transmission. The most common transmission types for the F-150 during that time were the 4-speed 4R75E and 4R70E automatic transmissions. Confirm that the 2005 transmission is the same type as the one in the 2007 F-150.
Engine Compatibility: Ensure that the 2005 transmission is compatible with the engine in the 2007 F-150. Different engines may require specific transmission configurations, so it's important to verify this compatibility.
Wiring and Electronics: Pay attention to any variations in the wiring harnesses, connectors, and electronic controls between the 2005 and 2007 models. If there are differences, modifications or adaptations may be necessary to ensure proper functionality.
Mounting and Driveshaft Compatibility: Check if the transmission mounting points and driveshaft connections are the same for both models. Any variations in these areas may require modifications or additional parts to ensure a proper fit.
Vehicle Configuration: Consider the difference between 4x2 and 4x4 transmissions. If your 2007 F-150 is a 4x2 (rear-wheel drive) model and the 2005 transmission is also 4x2, the chances of compatibility are higher. However, if your 2007 F-150 is a 4x4 (four-wheel drive) model, the 2005 4x2 transmission may not be suitable.
May 23, 2023 at 10:06 AM
