Instrumental cluster Intermittently not working properly
2008 FORD CROWN VICTORIA
160,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
XPALPHA
My cluster turns off and on at random. nothing works not even the diming lights turn on. none of my gauges work, but at random times it turns on. I changed my cluster but did the same thing, then I check the wiring harness that connected to the cluster and check it with the circuit tester some were good, notices one was flickering when I moved the harness.
Point is, I have no idea where to follow it and where it's connect to or even where to buy the whole harness itself.
Dec 6, 2020 at 4:00 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial for you to view on how to test wiring:
I've attached a wiring diagram for the instrument cluster below for your car for you. I've cut the picture into 3 pieces so you can view larger. Let us know what you find and keep us updated. Hope this helps and thanks for using 2CarPros.
Dec 6, 2020 at 5:18 PM
