instrument panel lights are flickering and display window on the right-hand side has strange symbols?
2000 LINCOLN CONTINENTAL
136,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
THE9A1968
MEMBER
FOLLOW
It does this for a while, then stops sometimes and other times it gets doing this head lights are not flickering on the panel.
Aug 23, 2022 at 8:44 AM
CERTIFIED EXPERT
This happens when the circuit board inside the instrument cluster goes bad which is common, you will need to get a rebuilt cluster just search google for a rebuilder in your area. Here is how you remove and replace the cluster have your VIN number ready.
Aug 23, 2022 at 11:24 AM
THE9A1968
MEMBER
Cannot get instrument cluster past steering wheel! How can I drop it enough to get it by? Also, I can't find any company that wheel fix the old one either.
Sep 11, 2022 at 11:42 AM
CERTIFIED EXPERT
You might need to get a used unit; can you tilt the wheel in one direction or the other to gain additional room?
Sep 12, 2022 at 4:08 PM
THE9A1968
MEMBER
I can tilt it down but still not enough room to clear it.
Sep 13, 2022 at 5:14 AM
CERTIFIED EXPERT
Remove the lower panel below the steering column and loosen the column mounting nuts. This will lower the column down enough to remove the cluster.
