instrument lights to dim to see. do not know how fast i am going. how do i correct this problem? Ray
Jun 1, 2017 at 1:54 PM
CERTIFIED EXPERT
There will be an adjustment that is near the headlight switch like a thumb wheel. Turn that one way then the other to see if there is a change and get back to me
Best, Ken
Jun 5, 2017 at 11:51 AM
RAY KAESER
MEMBER
Ken that wheel adjustment works well at nite but does not work in the day time RAY
Jun 5, 2017 at 12:19 PM
CERTIFIED EXPERT
Is it a LED screen or normal gauges?
Jun 6, 2017 at 10:57 AM
RAY KAESER
MEMBER
it is a LED screen, it gets dimmer and dimmer RAY
Jun 6, 2017 at 5:25 PM
CERTIFIED EXPERT
What is happening is the voltage amplifier inside cluster is burning out. This means you will need a rebuild cluster.
