need to know if i replace LCD and ribbon on instrument gauge cluster if current mileage will still show up?
Apr 14, 2018 at 4:13 PM
STEVE W.
CERTIFIED EXPERT
If you mean the driver information display, once replaced it will show the same information as before as that is stored in the instrument panels control section. If you replaced the entire panel then you would need to re-flash the unit to match your van.
