The vehicle won't go past 35 to 40 MPH, I'm guessing it triggers the limp mode. The warning lights intermittently keep flashing off and on in particular 4wd. oil pressure, check engine and battery/power light (lightning bolt icon) also the tachometer keeps fluctuating along with coolant temperature gauge once it reaches half mark. Engine oil level is at normal level. The vehicle is surging when you drive it as the RPMs keep going up and down. Backup lights won't come on either. I've installed a new battery, checked and cleaned all the ground points in the engine compartment and checked all the fuses and fuse box connectors along with PCM connectors and the ground wire in the engine compartment. When I tried to hook up the scanner and look for codes, it only gives me option for the engine control module and it says no other modules present, the engine module comes back clear without codes. When trying to run the alternator test for the same scanner it won't let me perform it as the RPMs keep cutting out to "0" losing connection I'm guessing. Please let me know what you think. Thank you
Oct 3, 2023 at 2:13 PM
