Couple questions. First did you just purchase this vehicle or what is the history of this happening? Did you replace the cluster and this started happening or did you replace it attempts to fix this and the new cluster is doing the same thing?
Clearly you don't need this video as it appears you have it apart but this is a video on a GMC cluster replacement that may help others as this process is similar on a Hummer:
https://youtu.be/_HEC44xENxw
Basically we are needing find out if this is different and what happened to cause the change? The cluster is responsible for running its own diag tests and initialization processes so if this is a new cluster and it was not doing it before then I suspect the cluster is the issue.
If this is a new cluster and it was doing this before then the only thing that would make sense is there is an issue with the BCM or one of the inputs from the BCM to the cluster.
The cluster does this sweep and chimes as a normal process to make sure it can communicate with everything it needs too.
Let's start with this info and we can go from there. Clearly it should not do this twice but without this info there are a number of things I am thinking this could be.
Thanks
Jun 26, 2021 at 1:44 PM
