Okay, is she having any issues with shifting out of Park or into any gear at all? The B1325 code being a low voltage code may or may not be related with the two U0155 and U2116 Cluster communications codes. On the networks, modules will send out a data message basically letting all the other modules on the network that they are active. thats what the U2116 code is about. The Clusters ID message is missing on the network. As for the U0155, Im assuming that code was set in the BCM itself. meaning that the BCM cant communicate with the Cluster. that code will usually set in the module thats sort of telling on the Cluster for not communicating. Since your gear select indicator is staying stuck in one position, its not receiving any signal from the Cluster that you've changed gears. So the Cluster is most likely not powered up or is missing its ground.
The Cluster has 2 powers, 1 Ground, and 2 communications wires. In a situation like this the first thing I would check is the Clusters powers and ground feeds. I would also use an oscilloscope to monitor the data wires to check if there were any communications signals coming out of the Cluster while its not connected to the network. But I dont think you would see any considering there are two communications codes.
Since power comes from the BCM to power the Cluster, if either power feed is missing 12volts, then you go to the BCM and see if the power is missing there as well. But this is after checking the 12volts and ground at the Cluster.
The 1st diagram below is the oem diagram for the Cluster, the 2nd is the aftermarket diagram.
Something to take note of, if power is missing on the Pink wire to the Cluster, which comes from the Run/Crank Fuse 2AMP, which in turn comes from the IBCM (RUN/CRANK) Fuse 21 30AMP. This circuit also feeds the airbag module as well as the Automatic Transmission Shift Lever. This may account for the other codes if powers missing.
The best way to check for power at the back of the Cluster connector is with a test light, it wont put much of a load on the circuit but it will give a clearer indication if the test light is bright.
I would actually use the Clusters Ground for the test lights ground, taking care of 2 tests at once. So the Pink wire and the Red wire with a White stripe on it are the 2 power feeds at the back of the Cluster, and the Ground is Black with a White stripe, Ive high lighted them on the oem wiring diagram.
Once you determine the power situation with the Cluster, that will give you further direction,
if the power feeds are missing and they are missing at the BCM as well, thats where thinks get tricky. Because the BCM controls so much, it needs to have all of its inputs and outputs, as well as powers and grounds checked, and they need to be load tested with a higher amperage test bulb, so youre sure the BCM feeds can handle a few amps. It can be difficult, although these BCMs fail alot, all the tests need to be done.
I've added the Cluster connector pinout (diagrams 5,6).
Feb 2, 2024 at 4:33 PM
