What scan tool do you have? It would be under special functions, or you can see in the first diagram i posted, it says to hook up the HDS which is the Honda factory scan tool. See on the middle diagram above where is says "Rewriting the ODO Data and Transferring the Maintenance Minder(TM) Data to a New Gauge Control Module.
When the old cluster is still hooked up in the vehicle, you would hook up a scan tool at that point to copy the cluster data, then install the new cluster and copy the data over to the new one. Im surprised you have any mileage on there at all. So somewhere in your cars network that mileage your seeing got transferred to the new cluster. Were there any instructions you had to follow with the new cluster? Im just wondering where that mileage came from. The new cluster should also have the VIN number.
Ok so it looks like the incorrect mileage you are seeing may have come from a different module on the CAN bus network. But obviously its still incorrect.
So you would need to have a scan tool that can read into other modules besides the engine computer. You would need something like an Autel or higher end scan tool to do data transfers like this. The last 2 diagrams below show how to redo the data transfer. And the only reason Im bringing this up is that its a Federal Law that the Odometer read the original miles or be reset to zero. Thats why they list that shop you can send the 2 clusters to. So it depends on what your scan tool is capable of doing..
Jul 12, 2022 at 3:04 PM
