Instrument cluster doesn’t work?
2014 FORD FOCUS
120,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
RUBENGR541
  • 19 POSTS
The instrument cluster doesn’t work. It doesn’t light up or do anything I checked the fuses and replaced them with new fuses and it still doesn’t work. I removed the cluster and cleaned the connectors with electrical cleaner and it still doesn’t nothing. There’s power to the connectors that connect to the cluster
Jan 18, 2026 at 4:15 PM
Yep, this happens when the cluster goes out and needs to be replaced or rebuilt. To be sure you can do a CAN scan. Here is a video to help you confirm the cluster failure, there is a chance the ground (g102 by the left kick panel) for the cluster is bad though, here is the wiring diagrams for the ground so you can check it.
CAN SCAN - https://youtu.be/u-4syLc-ifQ
how to check the ground
Jan 19, 2026 at 7:13 AM
