installing strut/shock assembly
1999 DODGE STRATUS
90,000 MILES • 2.4L • 2WD • AUTOMATIC
99STRATUSMANFRED
How to replace front strut/shock assembly? I bought a new complete strut/shock driver side assembly with control arm and i just want a rundown (with pictures if possible) on how to install it.
Nov 11, 2017 at 7:02 AM
Since you have the entire assembly, it makes things much easier. I have no pictures, but it is a straight forward job. First, remove all weight off the wheel which has the strut being replaced and safely secure the vehicle. After that, remove the wheel. Once the wheel is removed, locate the two bolts at the bottom of the assembly and remove. Next, there are three or four bolts under the hood in the strut tower which hold the top of the strut. Remove them and simply remove the strut. There may be a mount which holds a brake hose, so make sure everything is disconnected when you remove it. Also, the vehicle will require a front end alignment when you are done.
Nov 11, 2017 at 7:19 PM
