Installing a turbo
2015 CHRYSLER 200
34,000 MILES
OK.HELP
I want to fix my car listed above (Limited) into a faster turbo charged car, but don’t know what works needs to be done or where to start.
Apr 14, 2020 at 11:30 PM
Good morning,
The first thing that needs to be determined is if the engine is ready or assembled for adding a turbo. Inside the engine, you need to have a steel crankshaft and different pistons. The compression ratio needs to be around 9.5 or below.
It is not just as easy to add a turbo and life goes on. You may end up damaging the motor if you do not do it correctly.
What engine do you currently have in the car so I can check to see if your engine can handle it?
Apr 15, 2020 at 3:49 AM
