Installed a new blower fan and now radio, power locks, and the rear defroster do not work
2001 PONTIAC GRAND PRIX
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
STNICKWOODS
I installed a new blower fan in my Grand Prix, without any problems with the blower. However, I immediately realize that the radio would not go on and power locks did not work. The next morning I realize the rear defroster did work, either. I have check the fuses all three of problem systems that are fine. I went ahead and replace the fuse, but no luck. There is a wire harness behind the glove box that seem to no had a place to plug it in to. Could that be the problem?
Thanks
Jun 11, 2015 at 10:39 AM
JDL
  • 16,098 POSTS
Does the blower motor work OK? Did you unplug anything when replaced the blower motor? Anything you unplugged, you did reconnect, correct?
The other issues didn't start until you worked on the blower motor? For the systems in question, did you check voltage and ground, fuses and or relays? Did you check for voltage on applicable fuse circuit? Even if the fuse is good, if no voltage on the fuse circuit, when there should be, the circuit is still dead. Some fuses are hot all the time, some fuses go hot with the key on, some circuits may not go hot till you turn on the component?
I'd pick one system, check voltage and ground, go from there.
Jun 11, 2015 at 11:12 AM
JDL
  • 16,098 POSTS
Here are your radio fuses w/o amplifier. Notice one fuse is hot all the time, the other two fuse circuits goes hot with key on. Use a test lite to check for voltage.
If you want diagrams for other circuits, I can do that also.
Jun 11, 2015 at 11:20 AM
STNICKWOODS
New blower works fine. Prior to installed it the radio, power lock, etc worked. The resistor still need to be replace, but some other time. I check voltage, the radio fuse had current when on, but the radio amp does not on or off. I do not recall any wires I plug, but I do have huge hand and might one out accidentally and reconnect it incorrectly. Any thoughts?
--Thanks
Jun 13, 2015 at 8:39 AM
JDL
  • 16,098 POSTS
The fuse that had no voltage, that gets voltage from ignition main fuse 2, under hood fuse block.
That is for rap. May stay hot for a while after key is off, usually not very long. We may be wasting our time, checking that fuse.
Jun 15, 2015 at 11:35 AM
JDL
  • 16,098 POSTS
Just to add, fuse for power door locks is hot all the time. Also check for bcm trouble codes, see if anything comes up? Some of the national brand autostores may check codes for free.
Jun 15, 2015 at 11:42 AM
