installation of remote oil filter hoses
1996 CHEVROLET S-10
110,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
ROBBIEJBROWNE
Because of the large mounting flange, the old pipe/hoses will not wiggle they're way out of the obstructed pathway. As for removal I can cut the old ones. The problem persists when I try to reinstall w/ the new ones. The flange seems to large to fit through the pathway. Do you know if this is one of those situations where something like dropping the front differential a tad or raising the engine a little, is necessary? If so I'd appreciate knowing the correct method to accomplish whichever of these is the easiest?
Dec 27, 2014 at 3:46 PM
HOMER1967
  • 875 POSTS
I have done a few of these,and yes they are tight but they are doable.there are a couple brackets above the cross member that hold the hoses in place.i'm sure raising the motor a little would help.but it is not necessary.
Dec 27, 2014 at 6:13 PM
