Because of the large mounting flange, the old pipe/hoses will not wiggle they're way out of the obstructed pathway. As for removal I can cut the old ones. The problem persists when I try to reinstall w/ the new ones. The flange seems to large to fit through the pathway. Do you know if this is one of those situations where something like dropping the front differential a tad or raising the engine a little, is necessary? If so I'd appreciate knowing the correct method to accomplish whichever of these is the easiest?
Dec 27, 2014 at 3:46 PM
