Good morning,
There is a torque value for the nut that holds the sturt. I attached it here. If you cannot get this torque, you will need to replace the strut.
https://www.2carpros.com/articles/replace-shock-absorber
Install Strut Nut Wrench (on end of a torque wrench), Special Tool 6864, on strut shaft retaining nut (Fig. 30). Next, install a 10 mm socket onto hex on end of strut shaft. While holding strut shaft from turning, tighten strut shaft retaining nut to a torque of 115 Nm (85 ft. lbs.).
Please let us know if you have any other questions.
STRUT ASSEMBLY
REMOVAL
Warning: do not remove nut from strut rod while strut assembly is installed in vehicle or before strut assembly spring is compressed.
1. Raise and support vehicle.
2. Remove wheel and tire assembly.
3. If both strut assemblies are to be removed, mark strut assemblies right or left according to which side of vehicle they were removed from.
4. Remove screw fastening wheel speed sensor routing bracket to strut assembly (Fig. 24).
CAUTION: When removing nut from stud of stabilizer bar link, do not allow stud to rotate in it's socket. Hold stud from rotating by placing an open-end wrench on flat machined into stud (Fig. 25).
5. Remove stabilizer bar link from bracket on strut assembly (Fig. 25). To do so, place an open-end wrench on flat machined into link's mounting stud, then remove nut while holding wrench in place. Push stud out of bracket.
CAUTION: The steering knuckle to strut assembly attaching bolts are serrated and must not be turned during removal. Remove nuts while holding bolts stationary in steering knuckles.
6. Remove two bolts and nuts attaching strut clevis to steering knuckle (Fig. 26) (Fig. 27).
7. If servicing left strut assembly, remove nuts fastening coolant recovery bottle in place and reposition bottle with hoses attached out of way.
8. Remove three nuts attaching strut assembly upper mount to strut tower (Fig. 28), then remove strut assembly from vehicle.
9. To disassemble strut assembly, Refer to STRUT - DISASSEMBLY.
DISASSEMBLY
The strut assembly must be removed from vehicle for it to be disassembled and assembled.
For disassembly and assembly of strut assembly, use of Strut Spring Compressor, Pentastar Service Equipment (PSE) tool W-7200, or equivalent, is recommended to compress coil spring. Follow manufacturer's instructions closely.
WARNING: DO NOT REMOVE STRUT SHAFT NUT BEFORE COIL SPRING IS COMPRESSED. COIL SPRING IS HELD UNDER PRESSURE AND MUST BE COMPRESSED, REMOVING SPRING TENSION FROM UPPER MOUNT AND PIVOT BEARING, BEFORE SHAFT NUT IS REMOVED.
1. Position strut assembly in strut coil spring compressor following manufacturers instructions (Fig. 29). Position lower hooks on coil spring first, then uppers.
2. Compress coil spring until all coil spring tension is removed from upper mount.
Nov 30, 2020 at 3:25 AM
