Input/turbine shaft speed sensor A circuit location?
1998 MERCEDES BENZ ML320
328,111 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
DERRICKBENZ
MEMBER
1 POST
FOLLOW
Is this on the outside of transmission or inside? If outside, where is it located?
Aug 6, 2023 at 3:11 PM
CERTIFIED EXPERT
Yes, both speed input sensors are inside the transmission. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
