Where is the input speed sensor located?
2005 FORD TAURUS
170,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
BALOOMAN
Input speed sensor.
May 4, 2023 at 12:34 PM
I believe you are referring to the turbine shaft speed sensor.
To access it, you will need to remove the driver's side tire and wheel. Once it's off, you will be able to gain access to it.
If you look below, I attached the directions for replacement. Note there is an output speed sensor as well. Let me know if you need anything related to it.
Let me know if this helps.
May 4, 2023 at 7:50 PM
BALOOMAN
Thank you so much Joe, I found it. Truly appreciate your help.
May 4, 2023 at 7:54 PM
You are very welcome. I'm glad you were able to find it.
Let me know if I can help in any way, and feel free to come back anytime in the future.
May 5, 2023 at 9:53 PM
