inoperable right front turn signal
1995 FORD F-150
111,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
LABTEKLEN1
I changed the bulb with hospital gloves and put a new relay and I still get nothing from the front right passenger blinker outside, or in the dashboard. The back right passenger blinks normal. The driver side is no problem, the brakes lights, the headlights + the high beam and the emergency flashers light all the way around. Is there anything else I can do other than taking it to a pro. thanks im lost
Apr 11, 2016 at 4:40 PM
HMAC300
  • 48,601 POSTS
check for a broken wire leading from t/s switch or a bad ground.
Apr 12, 2016 at 6:16 AM
LABTEKLEN1
thanks HMA C300 it was a bad ground i didnt know that there was 1 for the hazards and 1 for the blinker
thanks again
Apr 13, 2016 at 9:32 AM
