inoperable radiator fan
2003 TOYOTA ECHO
63,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
ECHO ECHOS
single radiator cooling fan does not operate; no longer cycles on/off while driving or idle;
fan only operates on low speed when air conditioner in on. no fuses blown; installed new fan relays #1 and #2;
installed new coolant temperature sensor, all to no avail. what's left to replace
other than the fan resister and engine control module?
is there another relay or module controlling the fan?
vehicle has 63,000 is lightly driven, usually sits for months, used as second vehicle.
ran errands few days ago, fan never came on, no temperature indicator illuminated
on dash while driving, vehicle did not overheat. otherwise,
vehicle is in excellent condition.
May 25, 2016 at 8:09 AM
HMAC300
  • 48,601 POSTS
it may not need the fan to operate. the sensor tells computer when to turn on and it 'works when the air conditioner is on. as long as it is not overheating and fan is not working when that happens don't worry about it.
May 25, 2016 at 9:26 AM
