What is the torque value for inner and outer Tie Rods?
1997 MERCEDES BENZ E320
207,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHUCKDUARTE
MEMBER
FOLLOW
I've found as high as 110 nm for inner and 60nm for outer which seems high compared to other sites. What should it be?
Jan 11, 2022 at 11:55 AM
SQM
CERTIFIED EXPERT
Those specifications are correct.
The tie rod on the steering rack is 110 Nm (81 ft. lbs.)
Self-locking nut of the tie rod on the knuckle 60 Nm (44 ft. lbs.)
I have attached the instructions below.
Thank you.
Okay, the link you sent me shows 28 ft lbs at the knuckle vs 44 ft lbs that's why I questioned it.
Jan 11, 2022 at 12:59 PM
SQM
CERTIFIED EXPERT
Where do you see the 28 ft lbs? The self-locking nut could be 60 or 70 Nm depending on the color.
Jan 11, 2022 at 1:07 PM
CHUCKDUARTE
MEMBER
Per the link you sent on the first message https://www.2carpros.com/articles/tie-rod-end-replacement it's the third to last picture which has 28ft lbs in the text. Although I did see in the attachments the 44/81 foot lbs for knuckle and inner. Just letting you know it causes confusion.
Jan 11, 2022 at 1:37 PM
SQM
CERTIFIED EXPERT
Got it I see what happened. I included that guide just as a reference. As that is our standard tie rod end replacement procedure (different model).
The actual torque specifications are on the screen shot from all data that has your make and model.
