Inline fuel pump
1986 VOLVO 740
200,000 MILES • 2.3L • 4 CYL
DENVBRONCOS
  • 20 POSTS
Replaced inline fuel pump and car ran fine and few days later started bogging down. so checked to see if I could hear inline pump go on for a second after turning key and I don't hear it. I think pump I just put in is not working now.
May 1, 2019 at 2:56 AM
SCGRANTURISMO
  • 4,897 POSTS
Double check the electrical connections. A lot of times they can back themselves off if you are using ring connectors and nuts on a threaded post. Also double check the ground. Make sure all the paint is scraped off where the ring connector screws down to the body, making a good, tight, metal to metal connection. Also, make sure that the pump is as close to the tank as possible and as low as possible so that gravity feeds the pump so it doesn't have to pull the fuel out of the tank.
Thanks,
Alex
2CarPros
May 1, 2019 at 4:00 AM
DENVBRONCOS
  • 20 POSTS
Well fuel pump is working . it is bogging down but it seems like the timing belt might have jumped. Could any sensor that is bad cause it to advance or retard?
May 1, 2019 at 2:18 PM
DENVBRONCOS
  • 20 POSTS
It is a 1986/Volvo 740GLE non turbo.
May 1, 2019 at 2:19 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Yes there is. If a knock sensor was to get a short to power, then the Powertrain Control Module(PCM) would interpret this as an engine knock and would retard the timing to bring the engine back away from detonation,, but it would also set a Direct Trouble Code(DTC) and your vehicle's Malfunction ndicator Lamp(MIL) would illuminate. Is your vehicle's MIL or "check engine" light on?
Thanks,
Alex
2CarPros
May 1, 2019 at 10:49 PM
DENVBRONCOS
  • 20 POSTS
No check engine light on. I did try to adjust timing a bit and now I had to move way past my original mark. I was reading that if knock sensor goes bad that it would get stuck in retard mode.I have a 1990 Volvo I'm changing head gasket on right now. I might switch out knock sensor just to see if that is the problem
May 1, 2019 at 11:06 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Is your Malfunction Indicator Lamp(MIL) illuminated? If your vehicle's knock sensor was shorted to power if would set Direct Trouble Code(DTC) P0327 or DTC P0333 and illuminate the MIL "check engine" light. Get back to us, please.
Thanks,
Alex
2CarPros
May 2, 2019 at 11:00 AM
DENVBRONCOS
  • 20 POSTS
About to swap knock sensor. There is no check engine light on. It could possibly be my maf sensor. Before this, car would idle but dir when I'd press even a little on accelerator. Put maf sensor from a 1990 Volvo 740 turbo I also have and car ran good for around a week. Could it be maf cause its from a different year?
May 2, 2019 at 3:06 PM
DENVBRONCOS
  • 20 POSTS
It's a 1986 740 gle and there is no obd unit in engine bay
May 2, 2019 at 3:07 PM
SCGRANTURISMO
  • 4,897 POSTS
The MAF from the turbo should be just fine for the naturally aspirated vehicle. It would be a problem if it were going the other way around. I would double check the timing belt. It might have jumped a tooth or two.
Thanks,
Alex
2CarPros
May 2, 2019 at 4:18 PM
DENVBRONCOS
  • 20 POSTS
I did check belt and can gear mark lines up on mark on rear of cover at the same time as crank shaft pulley mark and zero degree mark on rear cover.
May 2, 2019 at 5:02 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
How about the cap and rotor?
Thanks,
Alex
2CarPros
May 3, 2019 at 7:38 AM
DENVBRONCOS
  • 20 POSTS
Checked cap and rotor, they are fine. I'm kinda thinking maf because when. I unplug it while car is idling real rough, it smooths out as soon as I unplug it. But will die if I attempt to push the accelerator.
May 3, 2019 at 11:42 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay. Mass Airflow Sensor(MAF) is probably the most important sensor on your vehicle. Your vehicle's Powertrain Control Module(PCM) uses the signal from the MAF to determine the amount of air entering the engine for it's baseline fuel map so it know how much fuel to add to maintain the proper Air:Fuel ratio. The MAF circuit is a complicated circuit but basically breaks down to a thin platinum wire that the circuit passes electricity through it. The resistance of the wire heats the wire to around 500 degrees. As the air entering your engine cools the wire, more electricity will have to added to maintain the 500 degree temperature. Your vehicle's PCM can now measure by the amount of electricity added to the wire the amount of air entering your engine and go it's proprogramed map to add the correct amount of fuel. Sometimes the wire gets dirty and skews the MAF sensor. Here's how to clean it.
https://www.2carpros.com/articles/mass-air-flow-service
Please go through this guide and get back to us with what you find out.
Thanks,
Alex
2CarPros
May 4, 2019 at 1:59 AM
DENVBRONCOS
  • 20 POSTS
I've already used maf sensor cleaner and didn't work for me
May 4, 2019 at 2:36 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Here's how to test the MAF sensor on your vehicle. I have included the diagnostic test procedure in the diagrams down below. Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
May 5, 2019 at 12:56 AM
DENVBRONCOS
  • 20 POSTS
Would it be possible to and me link to where you got the diagnostic information from?
May 6, 2019 at 10:03 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
The information is from Mitchell 1. I believe you would have to buy a subscription to use this service. I think there is a link on our homepage for you if you so desire.
Thanks,
Alex
2CarPros
May 6, 2019 at 10:29 PM
DENVBRONCOS
  • 20 POSTS
Also, thank you for the information on diagnostics page. Another question, where is the thermostatic air cleaner door located on my 1986 Volvo 740? Is it before the air filter box?
May 6, 2019 at 10:44 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
I have included the information that you requested in the diagrams down below. Please go through it and get back to us with what you are able to find out, or if you have any other questions, please feel free to ask. It's why we are here.
Thanks,
Alex
2CarPros
May 8, 2019 at 12:41 PM
