Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Van
Fuel System
Fuel Injector
Injectors not spraying
1995 CHEVROLET VAN
77,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
RICK J35
MEMBER
1 POST
FOLLOW
Injectors not spraying, noid light not lighting when I try to crank.
Sep 1, 2018 at 7:37 PM
CERTIFIED EXPERT
Good morning.
Did you verify power to the injector? I would do that with a test light or voltmeter first.
I assume you mean it does not flash? Is that correct?
It could be the ecm that has failed or it could be wiring to the ECM.
Sep 2, 2018 at 5:40 AM
