injectors issue
2002 FORD RANGER
150,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
GILBERT CARDONA
Fire to injectors no pulse.
Sep 9, 2019 at 11:54 PM
Good morning.
Does the truck have spark? The PCM needs to see spark signal before firing injectors.
If you do have spark, the PCM is bad as it controls the pulsing of the injectors.
If it does not have spark, then you need to check the crank sensor. Once you get a spark, the PCM should fire the injectors.
Sep 10, 2019 at 4:19 AM
