Injector leak off test results
2006 RENAULT MEGANE
120 MILES • 1.5L • 4 CYL • TURBO • 4WD • MANUAL
KING HADI SOUMARE
  • 22 POSTS
Greetings, I've done an injector leak off test. This is what I've found, but don't quite understand the results. Number 1 and number 2 injector had about 25 ml gasoil which seems normal. The number 3 injector has no gasoil returning at all, not even a drop. The number 4 injector has almost half a bottle, maybe 60ml. I can unplug injector number 4 and car starts with starting fluid and runs normal. If I start the car with injector number 4 plugged in I get a lot of smoke and smell. So I now I know there is a problem with injector number 4 but number 3 injector with no return. I don't understand.
Feb 28, 2021 at 9:16 AM
STEVE W.
  • 15,113 POSTS
The description sounds like injector three is plugged or the coil is shorted so it isn't moving the pintle off the seat. Injector 4 on the other hand is flowing in excess. If you have a volt/ohm meter you can use it to test the coil in the number three injector. Set it to ohms and test it, then compare that number to the other three injectors. Say you test number 1 and find 2 ohms resistance, then number 2 shows 2.1 ohms but when you test number three it reads infinity (open circuit) you know the injector is open circuit. Now say you test number 4 and find it reads .75 ohm. That would be an internally shorted coil. The control system is designed around somewhat fixed numbers. They determine the flow rate by pulsing the current to the injectors on/off. If the resistance in a coil is different than what the system expects you get the wrong flow rate.
Overall I would say a set of replacement injectors would be a good idea, that way they are matched for flow rate and you don't have many cylinder to cylinder power variations.
Feb 28, 2021 at 10:57 AM
KING HADI SOUMARE
  • 22 POSTS
Okay, thanks . That was helpful, I'll check the resistance tomorrow and get back to you.
Thanks again,
Hadi
Feb 28, 2021 at 12:30 PM
NICKOLAOSF
  • 69 POSTS
Hi KING HADI SOUMARE,
In your post you do not specify any codes or check engine light on. also is it 1.5l diesel or 1.6l gasoline ? I would second the injector having a issue.
Cheers, Nick
Feb 28, 2021 at 8:26 PM
KING HADI SOUMARE
  • 22 POSTS
Yes, it's a 1.5dci diesel k9k engine 724 I'm testing on 30 ohms, I get 00.9 on all 4 injectors. Sometimes moving to 10 or 8 but sitting on 00.9.
Mar 1, 2021 at 7:24 AM
NICKOLAOSF
  • 69 POSTS
Okay, when you do a flow return test in each injector look to see how much is it dripping or is there more of a flow if there is a more of a drip the injector is leaking. also did you have black smoke when you raise idle at the exhaust?
also drain your fuel filter in a clear clean container to see if there is metal shavings.
This sounds like you have.9 to 1.0 injectors are dripping more than they should. look to see if there is black smoke at the exhaust, if there is smoke find the injector that drips' more and replace it. and re do test flow return, if you metal shaving. there is failure at the injection pump.
Cheers, Nick
Mar 1, 2021 at 8:46 AM
KING HADI SOUMARE
  • 22 POSTS
Greetings, I made a mistake on the resistance my ohm meter had problems. So listen , inj. #1 and #2 have 1.5 ohms. #3 has 1.1 -1.2 ohms, inj. #4 has 1.2 ohms. Will that keep car from starting? If I disconnect injector 4 car will start with starting fluid and run normal, if I reconnect injector $4 it runs but with lot of smoke.
Mar 1, 2021 at 9:20 AM
KING HADI SOUMARE
  • 22 POSTS
With inj.4 connected I get black and white smoke. There were no metal in the leak off test. Injector 1 and 2 were normal about 20 ml diesel. Injector #3 has no gasoil return, inj.#4 has almost a full bottle, not normal.
Mar 1, 2021 at 9:28 AM
NICKOLAOSF
  • 69 POSTS
You have to drain your fuel filter at the pump to see if meatal shavings.
as for #4 has to much return, this one should be replaced, what you need from the returns is minimum fuel, black smoke is rich fuel in getting in to the combustion, possible dripping injector. you have to make a decision on replacing one at a time or replace all injectors,
Remember to wright down the number of the injector for each cyl and wright down the new part number you might have to program (https://youtu.be/s1bL2McGa0Q)
Cheers, Nick
Mar 1, 2021 at 10:06 AM
KING HADI SOUMARE
  • 22 POSTS
Okay, Nick thanks.one more question. Inj.3 has no fuel return when I did the leak off test. What does that mean? Also 1.5 ohms on 2 injectors and 1.2ohms on another does that make a difference?
Mar 1, 2021 at 10:27 AM
NICKOLAOSF
  • 69 POSTS
not even a drip? if no drip at all it could be clogged.
on ohms testing i can remember the specification, take a reading on all and if your average is about 1.2 to 1.5 you should be okay .you also have to replace one you can take a reading of the new or refurbished one.
cheers, Nick
Mar 1, 2021 at 10:33 AM
KING HADI SOUMARE
  • 22 POSTS
Okay, thanks.
Have a blessed day.
Mar 1, 2021 at 11:51 AM
