Vehicle running a little rough continued to drive and within a week it became so rough it rattles the window gets worse when I hit around 50 mph. Cylinder five misfire changed spark plugs five okay then six shows misfire. put on new coil misfire moved to cylinder two, now have 202 and 302 code errors. installed new injector resistance is 18, have pulse and power when checked with test light changed harness connector to injector. has a smell of fuel when started and that cylinder spark plug although new when checked again for correct gap thinking maybe it got bumped and changed. when installed had dark black build up on it. also when I pulled cylinder five plug during the replacement of all the plugs the porcelain was broken but the piece was wedged inside the top and was not missing any pieces that I could tell. my knowledge of auto repair is limited I get most of my information from YouTube or Haynes repair book, but problem remains unchanged. I would really appreciate any suggestion you might be able to offer me. Thanks, Dean
Apr 9, 2019 at 3:02 PM
