Injector failure
2003 RENAULT CLIO
160,000 MILES • 1.5L • 4 CYL • TURBO • 2WD • MANUAL
HENRIK2384
My car will only start when putting some starting spray in the air filter. Also, if it's running, I need to press the accelerator the whole time, otherwise it dies. I checked the camshaft sensor. A friend of mine told me, that the car is only running on 2 cylinders(1. and 4. ). We went to a mechanic and he told me that 2 injectors are broken. Could that definitely cause these problems? How do injectors even break?
Aug 10, 2019 at 8:34 AM
Welcome to 2CarPros.
It is unlikely that two would break at the same time, but I guess anything is possible. Usually, an injector will plug with dirt. Also, they have an electrical component to them that can also fail.
As far as causing a misfire, if an injector isn't working, yes it will cause it. Here are a few links you may find of interest:
https://www.2carpros.com/articles/how-fuel-injection-systems-work
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
If you decide to check an injector, here are a few links you may find helpful:
Let me know if this helps and answers your questions.
Aug 11, 2019 at 6:59 PM
