The screen sometimes goes black and whatever buttons you touch?
2011 MERCEDES BENZ E350
139,000 MILES • V6 • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
The screen sometimes goes black and whatever buttons you touch she won't awake, but i still have radio sound and all and if i change channels it responds just without visual, then i turn it off and in fee turn the car back on and the screen is fully functional. It can't be a fuse, is it possible the screen is going bad?
Jun 28, 2023 at 2:20 PM
Yes, this is common because of the heat in the summertime the side of the car gets hot and takes out the screen. I have seen the software fix it too but not that often, here is a TSB on the problem
COMAND: Does not start, cannot be operated, COMAND display remains dark
Topic number LI82.85-P-055695 Version 3 Design group 82.85 Navigation and communication systems (CNS, ICS, COMAND, FleetBoard) Date 08-28-2013 Validity NTG4.5: Model 207, 212, 218 with code 088 or code 803 or code 804 and code 512 (COMAND Online with integrated 6-disk DVD changer) or code 526 (COMAND Online without navigation) or code 527 (COMAND Online) or code 528 (COMAND Online without navigation) Model 166, 172, 176, 204.0/2/3, 246 with code 802 or model 166, 117, 172, 176, 204, 246 with code 803 or model 231 with code 168 or model 463 with code XZ2 and code 512 (COMAND Online with integrated 6-disk DVD changer) or code 526 (COMAND Online without navigation) or code 527 (COMAND Online) or code 528 (COMAND Online without navigation) Reason for change Damage code adapted
Complaint:
The COMAND unit does not start or the COMAND display remains dark. The COMAND unit cannot be operated.
Note:
The problem disappears after a lengthy idle period (>6h) or after interrupting the power supply (circuit 30).
Cause:
Software release of COMAND control unit (A40/3)
Remedy:
The power supply of the COMAND unit must be interrupted for a short time (approx. 1 min). Then the problem is rectified, but may reoccur.
Then perform a software update of the COMAND unit (A40/3). If there are complaints, the COMAND control unit must not be replaced!
The complaint is permanently rectified with the following software updates:
For vehicle models 207, 212, 218 with code 088: Software update of COMAND control unit (A40/3) to software release 12/47 00 or higher.
For vehicle models 166, 172, 204.0/2/3, 246 with code 802: Software update of COMAND control unit (A40/3) to software release 12/47 00 or higher.
Note:
To install the software, at least Xentry Diagnostics version 03/2013 and Telematics DVD 03/13 (A 166 827 11 59) are required.
For vehicle models 166, 117, 172, 176, 204, 207, 212, 218, 246 with code 803 or model 231 with code 168 or model 463 with code XZ2: Software update of COMAND control unit (A40/3) to software release 12/36 00 or higher.
For vehicle models 207, 212, 218 with code 804: Software update of COMAND control unit (A40/3) to software release 13/14 02 or higher.
Note:
To install the software, at least Xentry Diagnostics version 05/2013 and Telematics DVD 05/13 (A 827 02 00) are required.
Jun 29, 2023 at 12:12 PM
BHAMDOC1973
  • 2,008 POSTS
So, if it gets hot the screen starts to act up and sometimes works other times not, is that what you are saying?
Jun 29, 2023 at 12:38 PM
No, the heat ruins the screen operation over time so it needs to be replaced, but temperature can cause different operations and it could start working normally for a while.
Jun 30, 2023 at 10:01 AM
BHAMDOC1973
  • 2,008 POSTS
Replaced the screen which are cheap, same thing, after it runs for 10 minutes goes black. Have to wait until it's cold again for it to work again.
Jul 22, 2023 at 1:33 PM
Hmm, it must be the LCD driver module. Have you run a CAN scan to see what comes up?
Jul 23, 2023 at 1:43 PM
BHAMDOC1973
  • 2,008 POSTS
Yes, nothing came up.
Jul 23, 2023 at 1:56 PM
Okay, we are stuck with replacing the driver module or the entire unit.
Jul 24, 2023 at 11:02 AM
