Information panel not working
2002 LEXUS RX 300
236,000 MILES
SELKERN
Information pane is no longer displaying - internal temperatures, fan speed, time in travel, m/ph etc. The radio and clock are still lit up.
Nov 7, 2018 at 12:04 PM
There are four fuses that run the system I would check the dome fuse first. Here is a wiring diagram so you can see how it works and a guide to help you check for power with the locations of the fuses below. Check the wiring diagrams to see the other fuses
Nov 9, 2018 at 11:56 AM
