1999 Infiniti QX Car quit on wife
1999 INFINITI QX
FRANTICMOTIONZ
Engine Performance problem
1999 Infiniti QX Four Wheel Drive Automatic
Wife filled up at gas station and did not make it 100yards before car quit working. Battery good, car turns but won't start. Car ran fine up until fill up. Poor young parents, I'm good with tools please help!!!!!!!!![img:f149ffb136]http://www.2carpros.com/forum/automotive_pictures/588864_cori_car_1.jpg[/img:f149ffb136]
Nov 3, 2010 at 8:55 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem,Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Nov 3, 2010 at 9:07 AM
