engine shutdown while driving
2002 INFINITI Q45
CCHRISTOPHER7
Engine Performance problem V8 Two Wheel Drive Automatic 137000 miles
I was driving my car and it shutdown on me. No warning and I wouldn't have known for sure, but I couldn't accelrate and the steering was out. I was able to park, but when I tried to restart car, the engine wouldn't turn over. The electric looks fine as far as everything powering up.
Oct 13, 2009 at 5:25 PM
WHen you say it won't turn over, do you mean the starter doesn't work or the engine won't start.
Oct 13, 2009 at 10:22 PM
CCHRISTOPHER7
The engine won't start... The car was running and it stopped... I tried to start it up again and everything happened except for the engine finally turning over and starting.
Oct 13, 2009 at 11:07 PM
I need you to check for spark and fuel to the engine. One will be missing.
Here are the how to's for doing both. Let me know what you find.
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Oct 13, 2009 at 11:15 PM
CCHRISTOPHER7
Thank you.. Do you know how much it would cost to replace either one of those? suggest any reputable shops in my area that could fix this? could i dyi?
Oct 14, 2009 at 12:16 AM
FRANKINDA
Hi, I have the same problem. Were you ever able to fix your car? If so, what did you do?
Thanks
Sep 21, 2017 at 8:03 AM
This is an old thread but I have seen many people having problems with the crankshaft angle sensor going out in this car.
Here is a guide that will give you an idea on what to do with the repair.
and
Here are some diagrams of what it will be like on your car and how to test the sensor (below)
You will need to jack the car up safely as well
Please let us know what happens and upload pictures or videos of the problem.
Sep 22, 2017 at 12:35 PM
LMCKENNIE
Driving along and without warning the engine dies out (no service warning dash board lights), crank the engine one more time, car starts with just enough power to get out of the street into a safe park. The engine dies out again, already change the spark plugs, had battery recharged, no start. Battery did not fully charge up to 630 cold cranking amps, maxed out at 547, but engine turns over very rapidly as before previous time, before this problem. Please provide your assistance, and thank you for taking the time help me. Thanks
Sep 22, 2017 at 12:37 PM (Merged)
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge firt auto parts rent
FRANKINDA
Hi, I have a similar problem. Were you ever able to fix your car?
Thanks
