1992 Infiniti Q45 car starts but dies and fluxuates in RPMs
1992 INFINITI Q45
UP-SCALES
Engine Performance problem
1992 Infiniti Q45 V8 Two Wheel Drive Automatic 250k miles
I am trying to figure out why my infinity will start every time but will not hold an idle RPM and when I rev the engine it harmonizes at about 3 rpms and runs terrible. if i press the gas harder it will break through and reach higher rpms. if i hold at 5 rpms it will fluxate from about 4.5-5 and just when i think the engine is holding strong during the rev I slowely bring it back down to idle rpms. it may or may not hold for a few seconds and then the rpms drop and it just dies. the car will drive but I have to keep putting it in nuetral and reving the engine to keep it running other wise it will die even when in motion. please help. I will donate but cant spend alot as i know Im looking at possibly $700 dollars just for parts
Jul 29, 2010 at 10:36 AM
KHLOW2008
  • 41,814 POSTS
Hi up-scales,
Thank you for the donation.
When you are not able to hold idle, possible causes are :
1. Clogged idle control air passages. It can be the throttle body and IAC.
2. Bad compression or vast difference between cylinders. Get a compression test done to get the compression readings.
3. Faulty MAF.
Is the Check Engine Light indicating and have you tried to retrieve for trouble codes?
Jul 29, 2010 at 2:22 PM
