2001 Infiniti I30/Maxima ECM replacement
2001 INFINITI
MIKEW1025
The engine idle control valve failed and in the process damaged the engine control module. I've had the control valve repaired and need to replace the ECM. I'm taking a shot at using a used ECM ($200 vs $950). To be sure I order the proper replacement I need to read the part number directly off the unit. Where is it located (under dash, console?) and is it accessable without major disassembly?
Feb 23, 2007 at 12:55 PM
2CARPRO JACK
  • 11,533 POSTS
looks like it is under the dash in the center on the floor, behind center console
Feb 23, 2007 at 3:27 PM
