1994 Infiniti J30 egr valve and knock sensor
1994 INFINITI J30
18,500 MILES • 6 CYL • FWD • AUTOMATIC
SKIPFEET
where is the egr valve, and knock sensor located, and how hard are they to replace and clean myself
Feb 1, 2010 at 7:17 PM
1994 Infiniti J30 V6-2960cc 3.0L DOHC (VG30DE) Knock Sensor Location
https://www.2carpros.com/forum/automotive_pictures/12900_ks_1.gif
Located in the engine block valley. Knock Sensor Connector
https://www.2carpros.com/forum/automotive_pictures/12900_ks1_1.gif
1.Disconnect Knock Sensor sub-harness connector. Knock Sensor Test
https://www.2carpros.com/forum/automotive_pictures/12900_ks2_6.jpg
2.Check continuity between terminal (a) and ground. Continuity should exist. If no continuity exists, inspect Knock Sensor sub-harness. If sub-harness is OK, replace Knock Sensor. EGR Valve And Temperature Sensor Location
https://www.2carpros.com/forum/automotive_pictures/12900_egr1_1.gif
ECCS Components
https://www.2carpros.com/forum/automotive_pictures/12900_egr2_1.gif
Located at the back of the intake manifold, next to the firewall. EGR Valve Test
https://www.2carpros.com/forum/automotive_pictures/12900_egr3_1.gif
EXHAUST GAS RECIRCULATION VALVE TEST: Apply vacuum to fitting on valve. Replace valve if the diaphragm does not hold vacuum or valve spring does not lift replace valve.
Feb 1, 2010 at 7:39 PM
