driver window working great no hesitation or noise
let it down now it will not come back up had to take panel off to push it up and use tie wraps to hold in place don't seem to be off track it moves up smoothly when I push it in place. all other windows continue to work properly. Is this just the motor gone bad or are there other things to check ?
Also if it is the motor could you give me so hints about replacing it and if the window must be in a certain position when you replace the motor or if there is a calibration that must be done after motor is replaced
Sep 16, 2010 at 10:58 AM
