1993 Infiniti J30 blower motor works intermittently
1993 INFINITI J30
DEZ1
Air Conditioning problem
1993 Infiniti J30 6 cyl Front Wheel Drive Automatic 207K miles
Hi, quick question if you don't mind. My blower motor stops working, but never when I'm driving. Only when I start the car up. It doesn't happen all the time. I might go 3-7 days before I start the car again to find out the blowers not working.
But...if I tap the blower, located under the glove box, it starts right up.
Mechanic wants to just replace unit, but was hoping it might just be a simple and less expensive fix. Any ideas?
Thnaks again,
Dez
Jul 5, 2010 at 5:21 PM
SATURNTECH9
  • 30,869 POSTS
My suggestion is when it doesn't start instead of smacking the motor wiggle the connector and wire's around.If it start's working then you probably have a loose connection.
Jul 5, 2010 at 8:33 PM
JENREDHEAD38
What if the blower motor now smells burning metal after all 3 days of not working and tapping below glove box?
Sep 7, 2010 at 1:02 PM
SATURNTECH9
  • 30,869 POSTS
Unplug the blower motor and put the switch on high make sure you have power and ground to the blower motor connector.Also make sure you have a good connection to the blower motor.If all that is good and the blower motor smells burnt and doesn't work then replace the blower motor.
Sep 7, 2010 at 1:32 PM
